So I replaced all my missing door striker post bushings with a small length of PEX tube. The wagon rode a lot quieter with no door rattles. Then I got ambitious. My tail gate striker bolts were also missing their bushings. These appear to be a smaller diameter than the regular door ones. I thought I'd try it anyway and now I can't get the tailgate open either way, from the side or top down. Any suggestions?
Stuck tailgate
I would say try pushing from the inside while someone else is pulling the handle outside. If the bushings you made were bigger, it could just be wedged in the latch.1990 Country Squire - under restoration
Yup, that's exactly how you open them, and not just wagon tailgates but also regular doors that have had aftermarket bushings installed - said bushings used to be just the right size but over the last year or so I've been having nothing but bad luck with them, and when striker gets wedged inside the latch giving the door a good shove from the inside while having someone holding the handle open from the outside is the only way to free it again.The ones who accomplish true greatness, are the foolish who keep pressing onward.
