Roof leaks
    Roof leaks
    The 90 is leaking water when it rains. From the metal trim surrounding the headliner in the back. I pulled the trim and the water is coming out if the rectangular holes that the metal headliner trim attached to.
    it's a lot of water, enough to make a inch deep puddle in the rear underfloor compartment after a rainy day. Roof rack or side windows? It's not the tailgate window seal.
    I'll guess its the big side windows need to be re-bedded. Pull the trim around those and see if they aren't really stuck in there anymore.
      Thought I should follow up. Found the leak - foam between the tailgate window weatherstrip retainer and the body.
      See pics at http://www.grandmarq.net/vb/showthre...259#post779259
