here we go! quarter panel replacement (aka what have i gotten myself into)
Good luck man. I keep stalling on doing this to the escort. I hope it works out for you.~David~
you are replacing the outer skin yes?
Very nice work.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
yep, found a colony park in the boneyard a while back and went to town w/ a sawzall... i wish it were in better shape, but these don't come up very often 'round these parts anyway so i had to take what i could get. the original panel was crumpled and then repaired poorly (before i bought it).
yes, leaving the internal structure and just swapping skins. that's a lot of spot welds to drill out!
made good progress today, you can see the new panel mocked up w/ clamps. now comes the hard part -- putting it back together. i'm a total newb w/ a welder, and of course sheet metal isn't too forgiving.
i'm not looking for a 100 point restoration, just making it look better than it was.
Yes it is hard with a mig.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
should spray weld thru primer on all spot welds. http://www.youtube.com/watch?v=FKyu3...yer_detailpage
Originally posted by rellik god View Postshould spray weld thru primer on all spot welds. http://www.youtube.com/watch?v=FKyu3...yer_detailpage
now comes the "finesse" part, grinding down welds and trying my hand at body filler.
hope to get some primer on before winter really sets in!
If you can avoid submitting your primer spots to moisture (basically don't put the car outside in the elements when in primer) it will soak up all the moisture right through itself and fuck up everything underneath.~David~
Originally posted by 87gtVIC View PostIf you can avoid submitting your primer spots to moisture (basically don't put the car outside in the elements when in primer) it will soak up all the moisture right through itself and fuck up everything underneath.
