Marauder single exhaust conversion
    Hi Guys
    Well I have been driving my Marauder around for a few months now and quite frankley the exhaust drone from the tailpipes is really starting to grate, so I was wondering would a single exhaust system form a Crown Victoria be a simple plug & play fit or would I need some other modifications?
    Regards
    Dereck
    President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
    that would choke a 4v quite abit. unless you ran single 3 1/2"
    what is your current exhaust setup? is it all stock?
      Turn up the radio.
      1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
        Hi Jayh
        My current exhaust is the stock system and Pesty351 I tried turning the radio up but it doesn't seem to stop the drone from the exhausts.
        Regards
        Dereck
          How loud are the Marauders? Stock exhaust is usually tuned well enough to keep the sound out back where it belongs.
          1990 LTD Crown Vic w/ dead 5.0
          1984 Pontiac 6000 cammed 2.5L Iron Duke
          1986 F-150 300 6cyl 5spd.
          1994 Crown Vic... Free, bad trans?
            maybe you can put some caprice resonators on the tailpipes? that would quiet it down.
            I almost wonder if the stock mufflers are starting to rot inside?
              Get the 4" res-deletes.
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
                hmmmmm.......posted april 1st.......
                Former panther owner
                1981 CV 351 4bbl
                1991 CV 302 EFI
                  We have a winner.
                    Hi 351m
                    At 4200rpm with a sound meter microphone place at the hieght of the tailpipe and at a 45 degree, 18 inches behind & to the side of the tailpipe and in an open space it is 86db, which incedentally is the same sound level of my Excursion at 3000rpm
                    Regards
                    Dereck
                      Hi Dereck
                      I knew it wasn't true, because your Cartier has duals
                      Regards
                      GMGT
                        Anybody know if anyone make a TRUE X-pipe for an03 Marauder without having a custom one made ?
                          Try Mercurymarauder.net
                            Stainless Works makes exhaust kits for aeros and whales... they are very spendy, but also very high quality.
                            catback:
                            you might be able to call them and get just the X pipe, but it is 3" all the way and I think the stock pipes are 2.5.
