88 2 door GM from outerspace
90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All originalTags: None
An answer to a question no one asked.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Ive seen this on craigslist a couple of times. Not my cup of tea. Must be interesting though!~David~
Bronx special
Sent from my iPhone using Tapatalksigpic
Does thr transmission feed directly into the rear axle? Not much space for a driveshaft under there...The ones who accomplish true greatness, are the foolish who keep pressing onward.
That was a ton of work for little gain.1990 Country Squire - under restoration
Originally posted by 87gtVIC View PostIve seen this on craigslist a couple of times. Not my cup of tea. Must be interesting though!
I think someone shared the ad for this thing a couple of years ago.
Kind of like the aero panther wagon, this thing seems to pop up from time to time. Although I think I would prefer the aero wagon in this case.Vic
Seller from da Bronx with 0 feedback, sounds legit...just show up with the cash, nothing could go wrong1989 Country Squire - Twilight Blue, 347 stroker
Eh, I've done deals in shady areas before, it's not a bad idea to ask the seller how bad the neighborhood actually is so you know how much "help" you gotta bring along to ensure yours and his safety. If he says all is peaches you tell them that's cool but you'll bring a few friends anyways, and let him venture guesses as to what "friends" exactly you meanBasically he should see you as an equal alpha-wolf, instead of an unsuspecting lamb - then you become more potential trouble than you're worth, so he's more likely to just stick to the deal and all to be well in the end. Course it doesn't help if you do in fact show up with some reinforcements, which considering you're buying a car you'll probably be doing that anyways...
Looking at this car I would be worried about the owner getting all fussy after one points out all of the shady work that has been done. There has got to be a lot of it in this piece.~David~
Oh that's true, the car is a pile. Unfortunately it's the kind of pile that's no easily unpiled, so I'd think with something like that you're pretty much either running the POS mostly as is with some minor changes, or just pass on it entirely and if you want something similar start with a complete stock car and then do all the work yourself. Nature of the beast really...The ones who accomplish true greatness, are the foolish who keep pressing onward.
