1978 Grand Marquis
    I picked one up a few years back when I seen it pop up on eastwoods site. Glad I never had to use it yet. If only having the tools for the job really meant you would never have to do the job......
      I used it for the newlines as well. Definely practiced to dial it in. Niccopper def needs less pressure than standard.
      1979 Marquis creamy goodness
        Never did brakes on one of those but that looks right- hope you hooked up the parking brake cable before putting it all together.
        Nicopp kinks much easier though. Oops. Said that a lot my first few times working with it.
          So, I have purchased a new carb...a Quickfuel 680 Slayer, four corner idle have heard good things. Had a carb fire previously and the old one was beat to shit. Headers will be put on as well, this year.Gonna put a new throttle cable in and will need to remove the seat....since I will do that, its time to get rid of the 40+ year carpet. I bought the mass backing/ too expensive one on RA.
          Removed seats very easy, with the exception of the front seat lap belts. Broke a T50 and made the decision that they are staying there. I can cut the carpet to fish those through and honestly its in a position that no one will see it.
          Found the only weak point on my underbody/Floorplan. Sanded the shit out of it and other surface rust areas put copious amounts of por-15. Will be doing a fiberglass patch very soon. Sanded the front seat brackets and sprayed rust convertor.
ID:	1290088Click image for larger version
ID:	1290089Click image for larger version
ID:	1290090Click image for larger version
ID:	1290091Click image for larger version
ID:	1290092Click image for larger version
            Patched that hole. Much better. Thats Quickfuel Carb is on and definitely a much noticed response. C6 is starting to slip....new tranny is gonna have to be in the works. Cant complain have absolutely beat the shit out of it.
ID:	1290111Click image for larger version
ID:	1290112Click image for larger version
ID:	1290113Click image for larger version
              Carpet looks great. Fiberglass repair is pretty handy for weak but still intact floor repair.
                Carpet looks good. Did you have to do allot of trimming to make it fit ? Did you glue it down around the hump ?
                  It wasn't that bad, thought it would be much worse as I am assuming 78 GM coupes dont get new carpeting much. I trimmed like 3/4 inch on each side. The biggest issue was cutting the slits for the driver and passenger side floor seat belt brackets. I should have waited to do so after placing the seat down.....I did it before. The weight of seats pulled the carpet back from my original measurement. Not a drop of glue in case I have to get under there someday.
                    Carpet does indeed look good.
                      So about my trans slipping. Put it up on stands and started it up. Went under and pulled the line off the transmission modulator, definitely have vaccum.
                      While I was down there I noticed a leak and traced it down to my trans dipstick. Upon popping it off, the oring was toast. Went to a Ford dealer and no shit, they were able to pull up the part number. I think this would work for c4s and AODs as well. Dropped some Lucas trans slip, mechanic in a bottle and some Type F and ....it shifts fine now. It really is something thinking that a 44 year old trans can live this long.
                        Those seals are notorious for that too. I think the 4R7x uses the same one as well.
                          I like to think that if you don't beat on 'em, aren't a pedal stabber or erratic with throttle action and lock out gears to prevent excessive shifting, they'll last a very long time. I've never had one of mine fail.
