Yeah experience certainly helps make the next go around that much easier and smoother.
1978 Grand Marquis
Was looking at the lonely head under my hood and said what the hell, took off AC compressor, brackets, power steering pump, lines, belts...I took off the other head.
Glad I did, turns out there were two bent valves....brings the total to five. Along with a valve job...Getting some porting work done.... shit is not cheap on iron heads.Last edited by Grand1; 05-12-2018, 08:07 AM.
1979 Marquis creamy goodness
I wonder if you should have just saved the money, let the car sit and buy the aftermarket heads when you had the coin saved up. That's what I did with my Firebird. Valve guides/stemseals were bad and while it would've been cheaper to refurb them, I let the car sit for 2 or 3 years until I had the coin to put aluminum Trick Flow heads on it. Woke that turd right up.1985 LTD Crown Victoria - SOLD
Well I got a complete valve job (5 we're toast, the guides were to restictive as well). And only some exhaust ( "bowl work") porting. Cost me $375, I was gonna go for a full ports but didn't (your right about saving the coin) Didn't get the intake porting. So I didn't she'll out too much. This guy just opened a machine shop in Howell, it's called Adams engines. Worked for machine shops for 30 years and this is what he does in retirement. I walked in and started drooling Lunati cranks, Boss 5.0 blocks, scat pistons laying every where, ya know, the stuff of heaven.Last edited by Grand1; 05-14-2018, 05:11 PM.
For sure dude, wanna see what your ride is up too!
Yup, never got the conversion from r12 done, didn't work anyway. You want to get cool, stick your head out the window. Lol. One less pully, little more power?
Intake is on, she fired up. Got some valvetrain chatter now
Im tired. Get some pics up soon.
Did you check the lifter preload? If not, do that and that will tell us if you need different pushrods. You can ballpark it without the dial gauge though. It should hit zero lash somewhere about 1/2 to 1 1/4 turns before it hits torque. Thats with the valve shut. Looks like you're nowhere close to that. Different valve stem length, different base circle on the cam, different head gasket thickness, non-original heads, decking the block, decking the heads, all of that can require different length pushrods.86 Lincoln Town Car (Galactica).
