in harsh environments, with non-sealed systems like the boxes, every year. normal driving, typically 3-5 years. Flush should be done when it's changed. Back flush only if neglected.
sealed systems like aeros and whales... 3-5 years or every 50-100K miles is what I've been told. Again with the flush when changing.
If the juice is brown and nasty, and/or you have no clue how old it is, its due for a change. 3-5 years is fairly typical for non-crapped up cooling systems but if its amazingly nasty you might be flushing regular for a while. Use distilled water for best results.
I went a month with daily drain, flush, and refill sessions in an attempt to get rid of the brown sludge from my car when I first got it. I wasn't using antifreeze for that, just straight water during summer months.
I would echo these other fine fellows. Once you have it clean, install ALL new hoses then a premium 5 year antifreeze with distilled water.
The trick is marking the rad so you know when the next change is due. Maybe you can remember but five years is a long time and time gets fuzzy. I started using p-touch labels. I am surprised, so far the longest is on one of the cars about three years. Cleaned and dried the surface first. Paint also works, maybe you can find some of those door jam labels that used to be popular for recording services performed.
03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice 02 SL500 Silver Arrow 08 TC Signature Limited, HID's Mods>06 Mustang Bullet Rims 235/55-17 Z rated BFG G-Force Comp-2 A/S Plus, Addco 1" rear Sway, Posi Carrier, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17 12 Escape Limited V6 AWD, 225/65R17 Vredestein Quatrac Pro, Winter 235/70-16 Conti Viking Contact7 Mods>Beamtech LED headlight bulbs, Husky floor liners
