I finally got around to making a rear firewall so i can get rid of the rear seat. The delete is made out of .032" 5052 aluminum.
This is a shot from the trunk. I removed the center section of the original bulkhead, removed about 2-3 lBs. of steel and a 15# seat back. with the bottom it is worth about 30 lBs. of weight savings.
Im going to remove the upholstered board off the package tray and replace it with another piece of aluminum.
