I haven't tried it myself, but someone on here or CVN did and it uses the same plug they said. I'll grab one this weekend while I'm there and get back to you on price.
'95 Ford Bronco XL -
Pocket parts are good, especially since me and this mexican guy that has a sweet '81 GM are the only people around here pulling off the panthers, and if i dont get a part in the 30 days that the car is there it gets smashed
1984 Grand Marquis GS - CFI-SEFI conversion, Explorer 302, GT40 intakes, GT40P heads, 1.7 roller rockers, HO Cam, ASP Underdrive Pulley, 2.5" Dual exhaust, Flowmaster Delta 50 mufflers, 3.55 Trac-Lock, Rear disk's, Moog cargo coils, ES rear poly bushings, PI front and rear sway bars, 3G alt., Mark VIII fan, custom Auto-meter dash 1990 Crown Victoria Country Squire - Explorer 302, HO cam, dual exhaust, 3.55 Trac-Lock, PI rear sway bar (SOLD)
this is the same problem i had when i switched my digital clock over to the analog model. i had to make a specal braket to get it to work
the smaller one is for the analog & early digital, larger for the later ('83+) digital.
yes, there are 2 different analog clocks (not clunting the tripminder)
i found this out at work when an '81 LTD wagon came to the shop.. it was loaded and it had a digital clock. the difference is the display is slightly bigger, and the buttons are larger. but the unit itself is smaller than the later one.. why? because the later ones had to fill in the gap that the tripminder would normally fill.
