I'm going for as close to factory looking as possible. The only place I can figure to install some gauges is where the clock used to be. If my math is correct, in the pic below, I can fit 4 2 1/16" gauges in that area. What I was thinking was to cut out around the clock, and do up a plate with the holes for the gauges to go in place of it.
Any reccomendations on material to use for the plate and how to afix it to the panel above?
