I had my dash apart for the dreaded heater core replacement, so I took the opportunity to repair my cracked dash pad. It was probably in better shape than most. As you can see it had failed at the speaker holes and cracked out from there.
Sly did an excellent thread on installing a cap, which is a great option: http://www.grandmarq.net/vb/showthre...)-lots-of-pics
I have a friend that owns an upholstery shop, so I showed him the pad and we worked out a plan for me to repair the pad and him to cover it with vinyl.
Note that this approach covers up the speaker holes and the light sensor hole. I long ago changed to door speakers in the front, and I never use the light sensor (don't even really know what it does), so I did not care.
The basic idea was to patch the speaker holes with fiberglass and resin, trim away the curled-up edges of the cracks in the OEM surface, and fill with bondo as needed. I also trimmed some edges and other places that would have been difficult to wrap.
