I highly recommend the LMC light lens. I have them in the cars. Huge improvement. I also recommend Diode Dynamics for their LED lights I have them in the Subaru. 3 year warranty. Very good quality. On their site they show the application for the Mustang. 168/194 $8 ea. You can pick the color and intensity.Far better than the Ebay garbage. You can also call them if you have questions. They were helpful with me.
What bulb replacement for dome light :(
Some of the Chinabay stuff is OK, lots is not. the bayonet LED lamps that are in my gauges are flaky. One of them flickers badly, need to see if I can find either something better or a way to repair it. Probably a bad solder joint, the physical construction on those are pretty craptastic.86 Lincoln Town Car (Galactica).
specifically why I don't like the blue-white. It looks too modern.86 Lincoln Town Car (Galactica).
I like the blue-white in the accent lights in the grill of my car that helps signs "pop" at night while not being enough to really affect oncoming traffic. Just the wavelength addition to the regular headlights helps a lot at night to read signs. I don't mind it for the dome/map lights either. Dash lights, NO.
If it's just the color of the light bugging you, 3500K color (warm white) will look like the old bulbs.
Yes 3,500 to 4K is sometimes very nice. Not ultra blue/white but less yellow than the original incandescent. Do you know the frequency of the replacement bulbs you bought?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Most anything from www.superbrightleds.com that says warm white will be in that color range. Cool white will be 5000k or higher and typically 7500k-9500k.
