Finally got around to replacing the o-rings in my EATC unit. I edited out the “wrong” way...I may make a short video of that and post it to my Carport Shenanigans FB page if there is any interest in that. Thanks for your continued support guys!
EATC o-ring replacement: finally
'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.Tags: None
the fact that they never put proper electric actuators in these and bodged it together with 1970s vacuum motors controlled with an overly complex electronic vacuum valve mechanism never ceases to amaze me.86 Lincoln Town Car (Galactica).
Nice to see how it's done. I took a look at those spot welds and decided I didn't want to mess with them. That's why I retrofit the '03+ actuator unit into my stock control heads. I also noticed that your electrical connector on the actuator assembly is the 5 pin instead of the 8 pin like the older units. I'm not sure when that change came about, but it was definitely after '98.
In your case the '03 actuator assembly would likely plug in without modification to the electrical connector, and only require two holes drilled in the back of the head unit for the new location of the cover screws.
I think you'll be fine with the broken spot welds since the actuators are still mounted in the center just like the '03+ units which lack that outer frame. If not grab an '03+ ('03 and '04 for sure) actuator assembly from the JY (cheaper than buying the whole head unit) and swap it in.Vic
Another solution to reattaching at the spot welds would be JB Weld...also, as snug as the lid fits, some small adhesive backed foam strips would hold them down. I am curious now to see how the ‘03+ models are put together.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Thanks for the vid was fun to watch. Interesting.~David~
Originally posted by sick88tbird View PostAnother solution to reattaching at the spot welds would be JB Weld...also, as snug as the lid fits, some small adhesive backed foam strips would hold them down. I am curious now to see how the ‘03+ models are put together.
Link to that post (#30) with pictures and details on the retrofit: http://www.grandmarq.net/vb/showthre...l=1#post839773Last edited by VicCrownVic; 04-13-2020, 08:36 PM.Vic
Originally posted by 87gtVIC View PostThanks for the vid was fun to watch. Interesting.
VicCrownVic- that later setup looks MUCH easier to service. I may do that one day, thanks for the write-up and pics!'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Yep, super simple.
When I was researching the install of a '97 LTC EATC head into The Ice Car ('91 MGM, factory ATC with broken sliders) I wanted to change to O-rings before installing it. I looked up various write-ups/YT videos, which were done on '03+ units, and thought the job would be easy. After seeing what needed to be done on my '97 unit (break those spot welds) I took a trip to the JY to find a unit like the ones I was seeing in the write-ups. Yanking a few control heads in the yard is where I found the switch happened in '03. After comparing the two versions I determined swapping to the new one should be possible. I've done the swap twice now.
Here's a video that gives a good look at the '03+ unit: https://www.youtube.com/watch?v=hQusJQbT7rA
Like I mentioned earlier your repair will most likely be fine. The only modification for your '01 unit, since you already have the 5 pin electrical connector, should be drilling two 3/16 holes in the back of the head unit to accept the screws for the new actuator unit.Vic
