Hey guys,
Where do you mount your gauges? Other than the speedo gauge cluster and the face of the dash where the police gauges go; where to mount? I have 4 gauges that I should use (water temp, oil pressure, voltmeter, a/f gauge); plus the tach, which will be mounted on the corner of the dash; and the trans temp gauge which has its own pod. The only place that I can see is under the glove box. I can do that with the risk of people bumping their knees on them. A pillar will need modification/fabrication skills that I don't have at this time.
The police gauges: they must be flat gauges, as there seems to be not much room for regular 2-1/16" gauges. The back of them hits the inner panel. Plus, it appears that if I cut holes, they will cut into the HVAC ducting. Thanks for any input.
