Window motor grease?
    What do you guys use?
    Wheel brg ok or will it attack the plugs?
    Thanks
    Vaseline?
      Ky?
        I use the red'n'tacky lucas mucus that's in my grease gun. Have been for the past 7 years. No issues.
        I don't use the nylon bushings though, I have ball bearings in mine.
          Lucas Mucus, lol.
            I usually use white lithium or silicone grease. Some greases eat plastic. No bueno if you have plastic cage wheel bearings
              it hasn't degraded any of the plastic on the regulators or the motor gears. I use the silicon spray lube for the channels though. It also hasn't degraded the odometer gears either. So I figure after 5-7 years (depending on which application you look at), it's all good.
                I have used syn wheel brg grease most of the times no issues. some of them have been in use over 10 years
                  I use Sil-Glide. Stuff works great and doesn't melt. I have tried the silicon spray stuff, it never seems to last for me.
                    Thanks Bird, welcome to the party!
                      Ky?
                      LMBO!
                      OO, I shall have to have Ashley order a tube of this stuff for me. Thanks bird and yeah, welcome to the party man!
