Pillar gauge pods
    Pillar gauge pods
    Are there any dual a-pillar gauge pods that fit on box bodies? Fox body Mustang perhaps?
    So far my initial searching turns up dmccaig, I found 4 posts (3 from his old username) but I wasn't able to track down the pictures that are said to exist somewhere.
    What he has is for a T-bird, lightly heated to fit. He can probably explain better so here's a link to his most recent post on the subject: http://www.grandmarq.net/vb/showthre...l=1#post720969
    Vic
      I got a universal pod and heated it to fit the pillar cover.
        Have any pics? How well does it fit? I don't mind using heat at all, I just don't want to buy something that's totally different and can't be reshaped to fit.
          I can get some tomorrow, it's not perfect but will do the job
            Pick up a sunpro gauge cage. That is what I used. I then meticulously shaped it on a scrap pillar and then trimmed any edges on the pod so it would fit right. Used a screw in each corner and silicone to secure it to the good a pillar trim. Once the silicone cured (mega strong bond BTW once cured..I used regular black permatex) I removed the screws and in its places popped in hole covers that I found in bathroom cabinet display models. I painted them black so They blend right in.
            These are the ones I have made.
              Just holding it
              Molded to the pillar cover
                Not bad. Looks like it's a tad small width wise though. Doesn't cover the whole width of the pillar.
                87gtVIC what size gauge do those Sunpros fit?
                  That's a mid progress pic, I'll get one as it is now.
                  It comes almost all the way to both sides when formed to the pillar.
                    my problem is that I need a single 2-5/8 pod for my 93... best looking option so far may be a 93 lightning pod.
                      I used a Marauder gauge pod in my 96' molded with a help of a heat gun. It fit nicely.
                        2 1/16" gauges. No idea if larger sizes are available through sunpro. The sunpro gauge cages give you plenty of area to work with....trim to fit in the end.
                          that would be fine if I had a 2-1/16 gauge... but I have a 2-5/8 gauge and can't find a SINGLE pod for that. I can find triple pods with 2 smaller and one larger, but not just the single.
                            In case this comes up in a search, the one I made fit over the stock A-pillar cover by heating it was replaced by another that I made with fiberglass and a universal 3 gauge pod cut up.
                              Nice work!
                              Any other pictures of your car??
