Need help id'ing these switches
    its kind of hard to tell what some of the numbers and letters are but heres what I can read. Btw they are the three main switches off of my ATC
    E0VB-19A328-A2B (I cant tell if its a zero or the letter o)
    E1LH-19D961 (Not sure if the ones are the letter I or number one) (not sure if its the letter "D" is a zero or the letter "O")
    E4VH-19A642-AA (Not sure if the number one is the letter "I" or the number 1)
    Proud owner of a 1989 Crown Victoria LX LTD
    • Restored The Car Back To Running Conidition
    • Has a very well respected and cared for 107K miles on the odometer
    • Rebuilt 4 speed AOD Transmission *Original Trans Still in Car*
    • Rebuilt Front End with New Hub Assembly
    • 3rd Owner (Car has been in the family since 91)
    • They don't make cars like this anymore so it will be a definite keeper!
    Not sure but maybe pics of the switches and where they came from might help.
      First one is rear defrost switch.
      Second one is Heater / AC Damper Door Switch.
      Third one is HVAC blower motor control switch.
      You can find all this if you punch the part numbers into google.
        I found the blower motor switch and the heater/ ac damper door switch but im not having any luck with the rear defrost switch
          first hit with part number in google... http://fuelpumpsusa.com/AUTOPARTS_PI...vb-19a328-a2b/
          are you looking for parts to purchase or just descriptions?
            I clicked on the link and it showed a blank page, and im looking for purchases
              nevermind on the blank pages
                Does this work? You may not like the price so if not you'll need to check online Ford dealers.Bobby
                  found another for $30
                  REAR WINDOW DEFROST DEFOGGER SWITCH. IT IS IN GOOD WORKING CONDITIONS NEVER BEEN USED. NEW OEM ORIGINAL FORD OUT THE BOX. FORD STAMP PART NUMBER : E0VB-19A328-A2B. FORD SALES PART NUMBER : E0AZ-18C621-B.
                  has a large stock too.
                    Even better!!!
