I took the headliner out of my 81 LTD because it was sagging, and subsequently the insulation that was glued to the roof was also coming down, so I pulled that out as well, and will be ultimately replaced with Dynamat. However there is some residual glue and particles leftover on the roof, and I'd like a clean surface. I have tried WD-40 and a putty scraper and it's still fighting me. Any suggestions on getting it down? I can post pictures of what's left if that helps...
Insulation Adhesive Removal?
New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For SaleTags: None
Lacquer thinner should do it, or naptha. If you have a Zippo, try the lighter fluid. Thats basically naptha, though its more expensive than just buying a container of that. Lacquer thinner flashes off fast too, so I'd avoid that one in the summer if at all possible. You'll use a crapton of it.86 Lincoln Town Car (Galactica).
all that stuff flashes off fast around here... but it's hot here now so meh. I need to rip out (re: vacuum) all the foam off the headliner cardboard in the 88. it gets old brushing a knuckle on that and raining bits of crap on everything.
Originally posted by Mr Bean View PostGoo Gone should take it right off. I used it for removing glue left behind after removing the vinyl top.
The old stuff with Xylene and Toluene worked gangbusters on the roof snot, anything combined with acetone will be USELESS!
I had a can of the old stuff. Dump the liquid on it and a putty knife removed ALL the snot. The new shit was beyond useless!Last edited by sxcpotatoes; 07-07-2014, 01:07 PM.
id leave it honestly, the roof dents too easily.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
