MGM 2dr Door Panels
    MGM 2dr Door Panels
    Are the Mercs the only thing that will work for door panels on my 2 door? Found a guy with with a few Mark VI cars and a Crown Vic 2 door with the same color as mine. Will these work? Thanks
    Also, does anybody have a passenger side interior quarter trim piece? Burgundy in color.
    Interior door panels? The woodgrain (if there's an) probably won't match but the crown vic panels will fit. Not sure about the MVI but they'd probably fit.
      Yeah, interior door panels. Honestly its just the bottom part thats tore up on them. The top halves are just fine.
        The Mark VI panels are way different.
          CV and GMQ door panels will interchange without a problem.
            The carpet part you can re-do if you're handy. Abuse your gluegun. Elsewise, Vic panels work. Mark panels are different and i'm pretty sure the doors are longer anyway.
              I didnt think the Mark panels would work but thought Id ask since the guy had a few. If I found some Vic panels is it that big of a pain to switch over all my power stuff?
                Mark panels are molded and a different beast entirely. They're also thicker... by like 2 inches.
                  the power stuff all mounts in the arm rest, which is not really part of the door panel. It simply unscrews from the door seperately from the panel. Just use the ones for your Grand Marq and put the Vic panel in behind the armrest.
                    Got ya. Thanks. Didnt really think of it like that. I think I found a set and a dash pad in my color.
