Hole in Trunk
    Hole in Trunk
    Well guys I'm trying to figure this out I backed over a gas line with my panther and knocked a good hole in my trunk pan about a foot long by an inch wide so what could I do cause of coarse when it rains the bottom of the trunk gets water in it. What can I do to fix it?
    weld in new metal? or pop rivets and some sort of sealant.
      so weld it on from the outside?so the original matal won't rust away and then ill be putting a new floor pan in it.
        weld in a patch on the bottom side, and use seam sealer on both inside and outside edges. I'd probably also undercoat both the inside and outside to reduce risk of rot.
          Let your trunk be free.
            dam zach is that how rotted out the 92's trunk got
              It's still like that. The frame rails are ripped in half after the axle so the whole rear end kinda just sits there.
                take some pics so we can see how to advise you to fix it
