I think alot of people have the same problem: My tensioners all 4 of them dont tension at all. Is it possible to fix them somehow?
Another seat belt tensioner question?
“Cars are the only thing on earth that will beat you, break you, make you bleed, make you cry, spend all your money, spend all your time, not work and not care that you will love more, the more they abuse you.” -AnonymousTags: None
Only thing I know about is the situation where the retract-when-the-door-opens button gets stuck. On my two-door, neither front belt would retract at all when I first got the car, but removing the button thing and cable made them work fine. Though come to think of it, it's supposedly the cable that's problematic, and four-door front belts don't have the cable. Hm.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by monterey1962
