How to remove the headlight knob on an 86 grand marquis?
    hi i can't figure out how to remove the headlight knob on my car. i want to get behind the front panel to install some gauges but the headlight knob is the only thing keeping the trim on there. how do i remove it???
    Nick
    Reach up behind there, theres a little tiny spring loaded button on the body of the switch itself...
    pull the switch out, push that button in, push the switch in, and pull out. It may take a couple times before it works, but this is the method I use...
      I made a weekend out of mine
      But I was also installing other switches under it, and the things they operated.
      I wound up un-bolting that end of the dash and pulling back on it like a mofo to get my big hand all the way up in there.
      It felt like I was fisting a robot!!!
        I just installed my fog light switch today, in the same location where Pete has those three switches. I was able to reach my hand up from the below to get behind there, I checked to see and I was able to reach all the way up to the headlight switch, though my hands are probobly a little less than avarage in size.
          Actually now that I think about it - it wasnt getting my hand up there that was the problem, I could reach up and touch the switch fairly easy. It was twisting my hand around to that side in a way that i could push the release button that was the problem, lol its tight around the switch.
          I think in 90-91 boxes you just popped off some trim, take out 2 screws and the whole panel the switch attaches to comes out. Lucky bastards!!!
            :devil2: :devil2:
            aint that the truth, hehe. which reminds, i'm gonna spend 5 MINUTES to remove shifty's headlight. i don't have to contort myself or nuthin
            Save a seal, club a liberal.
              I think Towncars are also like that. The trim comes off then there are just 2 or 3 screws holding the switch to the dash itself.
                Yeah, it's something along the lines of 2-3 screws for the towncar switch. Have to check to confirm though.
