Ashtray removal?
    Ashtray removal?
    I have an ashtray that flips open located on the driver's seat back. There must be some way to remove just the recepticle to empty it. I can't figure it out, do you squeeze the sides or push down and pull? There must be some trick to it besides pulling off the plastic seat back and unscrewing it. Anybody know?
    if its the one I'm thinking of, you push down on the tab thats used to snub out the cigs, then the thing will tip out so you can remove it.
      Thanks, it worked just like you said.
