adding a center cosole
    i am getting a couple of free electric gauges from my auto mech teacher for free. I want to make a center console for them out of wood. Can you guys post your center consoles so i have an idea of how o construct it.
    just make a cardboard mock up, measure, then transfer it to wood. after that you can either paint, stain, or cover it with upholstery you like.
    if youre planning on covering it the wood will obviously be a lot cheaper.
    1988 MGM GS - Preferred Equipment Package 172A; InstaClear
    1994 MGM GS Montigua
    2002 Mustang GT Coupe
      see signature
        i am going to try to go with yours pete. Can you tell me the dimensions. Also i would like to see what other kind people made. I am thinking of covering mine in red vinyl, red velour, or red carpet. What should i cover it with.
          do you want to match the dash, the seats, or the floor?
            that doesnt matter as long as its red. i want to be creative here.
              If you want to be creative, then you decide what you want to use, lol
              I'd imagine carpet would be kinda hard to cover something that small with.
                its doable, though.
                  A few well placed cuts in the corners of the console that allow it to wrap smoothly around the edges should make it a lot easier.
                    I wouldn't carpet the whole thing. Not a fan of the fuzzys. Maybe carpet on the sides, or halfway up the sides, and then vinyl on the top/ top half of the sides.
                      well i made a cardboard mock up. came out better than i thought. what should your oil pressure be. At idle mine fluctuate around 25 psi then will drop when driving it to like 15.
                        You need 10 psi for every 1000 rpm, as a general rule.
                        I'd say 20+ at idle, and 35+ at cruise would be appropriate.
                        My '90 idled at 40, and was 55-60 at cruise/ WOT.
                          Carpeting the top would look nasty quickly, I think.
                            Generally you want more pressure when driving than what you have at idle. And pressures will always be high until the oil warms up and thins out. Are you sure you didn't have those numbers backwards?
