Originally posted by slymer
View Post
Tripminders in Aeros?
yes... in that 8 pin connector.
If you do install it... chuck the old one in the glove box. I need the case for another clock I have on hand here. I'm going to wire that one in to the truck somehow... one of these days... eventually.
Originally posted by slymer View PostIf you do install it... chuck the old one in the glove box. I need the case for another clock I have on hand here. I'm going to wire that one in to the truck somehow... one of these days... eventually.
blue/red is illumination (I'm guessing the trigger for dimming the numbers.
the reason I'd put it in my truck is cause it doesn't have a clock at all and the radio doesn't either and there's no good spot to put anything in that dash. I'm just going to kind of make a pod for it.
Originally posted by slymer View Postblue/red is illumination (I'm guessing the trigger for dimming the numbers.
Originally posted by slymer View Postit doesn't have a clock at all and the radio doesn't either and there's no good spot to put anything in that dash. I'm just going to kind of make a pod for it.
MUCH easier!2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by 86VickyLX View PostInteresting. So then what's the brown wire for? I hooked that wire up and the tripminder dims with the lights on. However the value of dimming doesn't change.
Originally posted by tjc78 View Post
Originally posted by slymer View Postin that case... it's backwards from what I was thinking (I haven't tested anything yet other than the fact that it keeps time). Brown must be the trigger while Illumination is the backlight... or would be a backlight. maybe I should open it again and trace the circuit board.
Wired in the fuel flow wire. There was a wire there. But I couldn't find any documentation of where that wire went besides the digital instrument cluster. So I ran a new wire. It's whatever. Tripminder is fully functional now.
John you make my electro-mojo gland tingle...!!!!!!!!!!!!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Just a wonderful job of making something that "doesn't fit" - fit!
