guess what this will be
    I know you guys can guess what this will be when it is finished!!! I had a brain fart and thought this would work pretty good and I wanted to get your thoughts on the hole idea!! Just had this stuff laying around the garage and thought I would give it a shot!!!!!!!!! Let me know what you think fellas!!!!!!
    '88' MGM wagon (mine and my sons toy)
    "60" chrysler New Yorker (my project)
    "78" Chevy 1 Ton P/U (yard horse)
    "01" Ford Explorer (wifes DD)
    "93" Chevy Suburban (my DD)
    sextuple gauge cluster bezel?
      fake straight 6 zoomies?
        I'd assume for gauges, but six?
          amp,volt,water temp,oil,vac,trans temp, and I could come up with a few more if you would like me to!!!!!!but yes you guys nailed it!!!!!!
            I was thinking you decided to get a plumber all upset.
              Are you going to fiber glass the entire thing?
                gadget,I am a plumber can't you tell!!!!!!
                87, not sure how I'm going to finish it yet!!!!!!!Have a few options and depends how the glue I used holds up!!!!!!
                  I have 6 now, engine temp, trans temp, oil psi, vacuum, volts, and A/F ratio.
                  I'd like to have another to see trans line pressure, hot rodders might want one for fuel pressure... more feedback from your car is always better.
                    thought they were gonna be fender portholes lol
                      I thought it was the beginning of a really nice bong
                        sssshhhhhhhhhhhhhh don't tell anyone!!!!!!!!
                        OK now how about your opinions on the hole thing!!!!!!!!
                          Don't do an amp gauge. You get pretty much the same information from both, so you only need one, and the amp gauge runs the entire output of your alternator through it. So unless you want all that juice going into the dash and then back out, and potentially shorting out on any number of things, just stick with a volt gauge.
                          ....that's one hell of a bong.
                            the only reason I was going to use an amp gauge is it came in a 3 gauge set that I already have!!!!!!!! but you are right there is very little difference in the two!!!!!!!!
