well i went to the junkyard to replace my speedometer with the more modern 1988-1989 GM speedometer i like it better, it all was plug and play and the only real difference on this speedometer is where the oil light isit's a engine light and were the temp light it's a check engine light i used my existing plug to plug it in i did manage to cut the end of the plug for the 88 speedometer in case it's different wiring. is it different also if it is can you tell me what wires to hook it up too.
Switched my 1983 Speedometer with a 1988 Speedometer
1998 Ford Explorer Limited 5.0 AWD(Fiona)-Mods: Lincoln Navigator THX Audio System, Ford Explorer Sport Instrument Cluster.Tags: None
just now know that if the check engine light is on it means i am overheating and the Engine light is my oil.
Originally posted by MattsGrandMarquis View Postjust now know that if the check engine light is on it means i am overheating and the Engine light is my oil.
hmm might do. tell me more please on how to tutorial.
they can't be switched the 1988 uses square shaped warning light the 83 uses rectangular warning lights. won't fit right.
what about swapping out the whole side of the cluster? don't they mount to the casing the same?
check my readers ride thread i will post some here later.
