Soooooo..... After 6 hours I got a little somewhere. Now I am wondering if I can get to the blend door and ATC with the dash like this. The reason I ask is because there is a mass of giant wire that runs from the firewall to the fuse box... under the dash (clipped all the way) to the other side and back into the firewall. If I want to take the dash completely out I need to take this wiring harness out, which looks like another 5 hours of work.
Here are some pictures... I want to replace anything that could be responsible for my A/C blowing hot air (80*) and my heat only blowing the hottest air. I have had the A/C blow cold on occasion and the under hood blend door has been replaced by the previous owner, and the HVAC unit has been replaced as well. The pump engages when I turn the A/C on so it leaves the under dash shit as the culperate.
Could somebody point out the part on the blend door that controls it's opening/closing? Also I know the ATC is under the dash pad with the white hose going to it, is there anything else that should be replaced while I am under here?
pics...
^ I think that white box is the blend door switch?
pics...
