How would i go about removing this without breaking any serious stuff? I need to swap it out with another one as it isnt staying locked anymore..
Removing drivers seat belt buckle?
Should be a T50 torx bit that goes on a 3/8" ratchet. Buckle is bolted to the floor. Not too much trouble to get those loose, Torx bit can be bought at any auto parts store for a few dollars. (Unless Ford changed the size of the bit, not 100% sure there, but my '87 takes a T50.)"Beasty Cruiser" '87 Grand Marquis LS 2-Door - Too much damage took its toll. Transmission blew, now a parts car.
Yeah, it was either T50 or T55, think it was T50. Hopefully yours isn't rusted completely in place like one of mine is - I've tried oiling and gentle heat-persuasion, but I don't want to apply too much heat right next to the fuel line, so I'm planing to go at it a little more aggressively when/if I get around to replacing and upgrading the fuel line.2012 Mazda5 Touring | Finally working on the LTD again!
They sure are a bitch if they are rusted from the underside. When I first removed them from my car I used a 1/2 inch ratchet with a 1/2 -3/8 adapter just so I had more leverage on it. Now everything is easy because everything has been apart hundreds of times.~David~
buy a spare T50 bit!!!sigpic
You can also crawl underneath the car and spray some rust penetrant on it.~David~
