How hard would it be to make these work?
    SRP Sullivan Racing Products, Inc. custom aluminum racing pedals made in the United States since 1995.
    I can't imagine there being much difference between pedal styles, but it say 92 up, and It would be fairly killer to make them work in a box. Are there any huge differences between the styles? Can these be adapted to fit?
    I found the link on MM.net, if anyone is wondering.
    I'm guessing the worst case scenario would be you'd have to weld some sort of clamp/clip onto the pedals to mate up with the pedal...arms? levers? whatever you call what the pedals mount onto.
      I had aftermarket pedals on my car for just under one year. I made custom brackets to the accelerator pedal cover and even chopped the accelerator pedal rubber so all I would see was the new pedal cover. I never liked it because the new accelerator cover was wider and prevented me from mashing the pedal. I guess that is why our pedals are that skinny from the get go because they are already smooshed up against the tranny tunnel. This pedal cover is a bit narrower but you may still end up with the same problem. I will admit though that the covers I had were the bomb but after time I just didnt like them and the factory stock look was much more appealing.
        methinks this is accomplishable. I don't have a problem with welding, so mealsothinks that I can do it fairly easily.
          Looks to me like they have holes for counter-sunk bolts. Could you just drill and tap your pedals? If there's not enough meat there for tapping, you could always tighten a nut against the backside of the pedal.
            Accelerator pedal is all plastic. Dont know if that ruins welding plans or not. lol
              that could also work. I'm under the influence that those are pedals to replace the pedal pads, not go over them. Which would mean there would be bracketry somewhere. Where? I have no idea. I might just have to order a set and see if I can fab anything up.
