my passenger side seat in my marquis is a manual move seat no power to it. i was wondering if the chord to make it a power seat if i want to is underneath the carpet. Does anyone know if the wiring to a power seat is underneath the floor if the car has a manual seat. i don't want to tear up my carpet if that wiring chord for an optional power seat install isn't there. Do the keep that chord under the carpet or do they not put that in at all. Was hoping to switch it to a power seat but didn't want to if the wasn't any chord there to hook it up to.
Manual front seat to Power
1998 Ford Explorer Limited 5.0 AWD(Fiona)-Mods: Lincoln Navigator THX Audio System, Ford Explorer Sport Instrument Cluster.Tags: None
it might have the wire under the carpet for the power seat track......not sure on a 83.....if it isnt there it is no big deal to tap power off of the drivers side seat motor plug
I did not have the harness underneath the seat. Here is a thread about how I installed my passengers side power seat. http://www.grandmarq.net/vb/showpost...&postcount=235
It is really simple to pull out the carpet mang and tap into the drivers side harness.
What you will need to buy is a p. side power seat controls and the harness for it as well as the power seat tracks with motor.~David~
which i can get at a junkyard off of one that has a power passenger side seat.
what do you mean by tapping the drivers power seat. i don't want to have it not working right after i attempt this.
Originally posted by MattsGrandMarquis View Postwhat do you mean by tapping the drivers power seat. i don't want to have it not working right after i attempt this.
All you do essentially is find out which wire of the two is HOT all of the time and cut away some of the insulation and wrap around the new power wire and solder/tape etc them together.
The only way it wont work is if the motors are shot to begin with.~David~
When i did mine, I fished the power wire out of the junkyard car all the way from the seat to the plug-in power panel under the dash. In mine the spot next to the drivers power seat plug was empty and hot, so I just plugged it right in.
Its not hard to fold the carpet back in one piece once you have the seat out and the sill trim panel off.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Mine too. I just ran the wire under the carpet. Had both seats out so I could route the wiring. Pete's way sounds very clean and professional... doesn't sound like pete at all. JK pete. If you could harvest the whole harness, that would be great. And if you have some way of testing the seat track before you buy it, do it. One of those 12v booster packs would be perfect for that. Mine has come in handy many times!!
Installing Power Track Seat
well i went to the junkyard yesterday and got me a passenger power seat assembly and track. I installed it today with a few modifications to fit it to the floor bolts. after it was done the seat looks like it is high on one side and low on the other side. I messed with the controls straighten the seat out and still no luck. When you sit in the seat it tilts to the right side. it looks like shit. this is what i got at the junkyard.
Power Seat controls and track assembly from a 1990 Ford Crown Victoria.
I don't get it does it have to be a 2 door track to wrok or can it be a four door. What is my mistake.
you need a 89 or older power seat track......they changed the floors in 90 getting ready for the aero panthers
thank you so much scott. does it matter if it is a four door or two door.
ok does anybody know which years the boxes had the wire under the carpet and were it runs too.
Originally posted by 86VickyLX View PostSome had it others didn't. You can run the wires from the fuse box under the carpet and to the seat. Petemang did that. The switch should work the same regardless of the year.
I'm trying to remember, but it seems like the switch is what's actually side specific. I know I ended up repinning a switch harness when I broke a p/s switch and replaced it with a spare d/s switch.Last edited by 1987cp; 03-24-2010, 03:46 PM.2012 Mazda5 Touring | Finally working on the LTD again!
