Back right door wont open from the inside?
    Ever since i had my 97 grand marquis, everything is in perfect condition except for the back door. It opens fine from the outside but when your inside it wont open? It sounds like it might be a child safety lock or something of that nature or even a problem with the door from the inside, i was wondering how i could fix this and what might possibly be wrong?
    79 Grand Marquis
    A rod may have popped free from the handle. Since you'll need to do it anyway, take off the door panel and look while working the handle to see if the rods are moving back to the latch mechanism.
    Alex.
      Do these cars have that child lock thing? Some cars have a little switch on the rear edge near the latch that you can flip to disable the inside door pull.
        I played around with the door, everythings working fine on the inside, its my child safety lock thats sticking. I played around with it and it seems to be working okay for now. The original owner said he never even knew the door didnt open. Handle and everything seems to be fine.
        79 Grand Marquis
