Door lock question
    Door lock question
    ok i got into my car the other day and started it up(it just started getting really cold and snowy up here) and upon starting it my door locks automatically locked... not normal.. but anyway so i drove it for a while then all hell broke loose and now they are constantly unlocking and locking...
    1. it now continues to unlock and lock even if the key is not in the ignition and will only stop when i unhook the battery.
    2. i pulled the fuse in the dash and the probelm still persists.
    3. I think there is another fuse link up by the starter relay is this correct?
    other than that last part i am compleatly lost and feel like i am driving a car from the exorcist.
    Its one of the fuse links. I'll bet one of your lock or unlock switches has gone batshit on you. I'd start by pulling the switches one at a time to see which one stops the problem. Probably some moisture in there if I had to guess.
      makes sense ill have to take a look at that tommorow
        they're just in the halloween spirit. Leave it as it is and scare your friends with it.
          If you tell me the year of the car, I might be able to find a wiring diagram for you.
