I'm having window problems in my 2DR GM. Before this it has had few problems beside a loud squeal going down but, today at a drive thru it went down 1/2 way fine and refused to go up. Strange thing is 'tho it will still go down fine. Any suggestions on what may be the problem? Thanks...
Window Problems
it might be the window switch. i replaced the switch for the drivers window today on the wagon. had the same problem, went down but, not up
Does the motor make any noise that sounds like it's trying to go up? Do the lights dim when you try to put the window up? If not, it's possible that the switch terminals are just corroded. Give them a good cleaning and see if it helps your problem.
i got mine from the parts car i had once apon a time. a 4door switch wont work on a 2door. i remeber with my lincoln back in the day, the harness part where the switch plugs in was burnt, so that might be a possibility.but, im still gonna say switch if your window goes down.
I had the same problem a couple of months ago. All i did was remove the switch and plug it back in lol That was all. And if your window is still down, rip off the door panel and switch the wiring to the window motor just so you can get it back up.~David~
Glad yo were able to fix it. My wont go up because of the rubber mold around the window area. I would have to open the door and push the glass to stay behind the mold.2004 Ford Crown Victoria P71 (Frost-Bite)
2007 Chevy HHR
