My 84 tudor has the small vent windows and round handles. How do you remove the handles so you can remove the door panel?
Vent Window Handle Removal
NA-15.78@91.21, 80hp shot-14.48@96.21Tags: None
If its held in like with a clip like no-screw window cranks, you can usually floss a rag around between the knob and door panel to pop the clip out.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
peel the metal disc sticker off and take the screw out
Originally posted by p71towny View PostYou have to carefully pull the aluminum disc that is in the center of the handle and remove the screw.
