I told you you could move it, now see if the system still funtions properly.
so far with no trim reinstalled everything works just fine. Too much rain today to do anything. I wanted to run all of the gauge wiring today, but i dont exactly fit that well in the car with door closed trying to wire stuff under the dash. Just not gonna happen.
Yesterday was a complete washout...so all i got done after my day was this....Muhahahahahah!!!!!!!!!
I may cut the rest tonight. I have ugly calluses now because i used a razor blade to cut the material thus far on the trim panel.
And today after school and homework was complete I removed the dual gauge pod a pillar i have and routed a headlight triggered power wire, and good ground and the amp gauge wires to the massive gaping whole on the passengers side dash. Some time during this week (i hope) i will route the air/fuel gauge wires and purchase a vacuum gauge.
Take a look at my collection now.
A double gauge pod pillar, a single gauge pod pillar and a naked pillar that will go on the car next. It has come to my attention that i like to change thins around often.
I didn't realize that thing had such direct control of the blend door!! I had always thought it was just a sensor, not a vacuum control as well.
I guess the other end of that cable is attached to the temperature lever on the HVAC control?
Yes that damn freakin frackin cable is indeed attached to the temperature lever on the HVAC control. Feakin ATC equipped vehicles. FFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUU.
Oh and thanks, hopefull this will allow future panther owners to embark on the task of equipping a ATC equipped vehicle with police gauges. Or i just wasted my time lol. I enjoy it.
