can i put mustang buckets in my mgm or will the power bench setup not allow it ? and if i install a grant steering wheel will it eliminate the airbag or can i still have yhe airbag ?
seats , steering wheels ?
The short answer is yes; how difficult it will be depends on specifics of the seats' construction and what sliders you want to use. Blaze, Bowman85Merc, Duce, and I think Turbo all used some sort of universal slider and did some fabricatory gymnastics to make them fit. It's also not that difficult to make bracket adapters to mount various seats to your stock power sliders, just keep in mind that such adapters tend to add height, which is the main reason I eventually removed the seats I had installed using that method. Aggravatingly, I've discovered that there exist certain manual sliders that make certain seats a bolt-on deal, but the only place I know so far to find them for certain is off of '87 and older Vic cop cars with nonreclining bucket seats ... the seats seem to be rather rare these days, and the brackets are turning out to be incredibly hard to come by separately from the seats.
Why do you care about retaining your airbag? If I had one, I'd be glad to be rid of it.Last edited by 1987cp; 12-10-2008, 02:34 PM.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by olskoolcrownvic89 View Postcan i put mustang buckets in my mgm or will the power bench setup not allow it ? and if i install a grant steering wheel will it eliminate the airbag or can i still have yhe airbag ?
@1987cp: Airbags save lives. One saved my life, at least. And you get an insurance discount.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 91waggin View Post@1987cp: Airbags save lives. One saved my life, at least. And you get an insurance discount.
Insurance discounts are retarded. Circa 1990 GMs with the seatbelt mounted to the door get a "automatic seatbelt" discount, despite the fact that it's all but impossible to exit the vehicle with the seatbelt still fastened. I know, because I had one, and yes, I unbuckled my seatbelt every single time I got out of the car.
Besides, if I were ever in a wreck and a big watzit blew out of the dash and bashed my glasses into my face, I think I'd be more than a little annoyed. Instead of just having to search for my glasses for a minute or two, I'd be at the hospital having them extracted from my face, possibly with one or more lacerated corneas. No thanks!
Originally posted by olskoolcrownvic89 View Postreally i could care less about the airbag , i think i have a solution to the seat problem tho2012 Mazda5 Touring | Finally working on the LTD again!
i was at work today and clearin the yard out and noticed an old airboat seat mount , they mount in a variety of ways , but this one was mounted similar to a dragster . i plan to do the same mount out of thinner metal that will lay on top of the existing sliders . i should be able to mount the summit seats and not really change the height and still have use of the power seats .........hopefully , ill try it on the test vic first
Sounds neat, hope it works out. I had been under the impression that most non-Panther seats tend to be taller in the cushion that a stock split bench, but it'd be neat if I'm wrong.2012 Mazda5 Touring | Finally working on the LTD again!
