I recently found a 1990 140 speedometer in my basement and I'm wondering if i need to do anything to install it or will it just drop right in. thanks in advance for any advice and input.
140 speedometer for 1990 CV
You would need to change the gear in the speedo with the one in your original one so that the speedometer is accurate, unless you know which rear the car that had the 140 speedometer had. If it has the same rear as the one that's in your car, it's direct bolt on, no changes required. Also, the older ones had this tab that wouldn't let you go to 140, not sure if the '90-'91 styles were like that too.
Originally posted by crown vic muscle View PostThanks for the info. i have the speedo apart to clean it and scan the face for a possible white face swap. i have a few speedo gears in the basement that im going to try to see if i can get it right, otherwise its off to the parts counter at ford.~David~
the gear you change is in the transmission, NOT in the speedometer...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View Postthe gear you change is in the transmission, NOT in the speedometer...
And you shouldn't have to change it for a speedo swap.1990 Country Squire - under restoration
The needles in a fully electronic cluster (like the 90+) will usually flop around if you tip the thing. I know they have in my car when I've pulled the cluster for various reasons. As long as you haven't fucked with any of the needles, as soon as you plug the cluster in and turn the key on, all the needles will go back to where they're supposed to be.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 85crownHPP View Postthe gear you change is in the transmission, NOT in the speedometer...-Phil
Originally posted by 85crownHPP View Postthe gear you change is in the transmission, NOT in the speedometer...Originally posted by Tiggie View PostX2
And you shouldn't have to change it for a speedo swap.~David~
thanks for all of the responses. I just wanted to make sure that I wasnt wasting my time by putting something in that wouldnt work. I will be scanning in the 140 face and trying to make a white one with a laser cutter and some plastic stock. I will try to keep posting with my results.What happened here?
