Got a question for anyone who's removed a full bench seat in favor of either a split bench or buckets. I was looking at the floorboard (top and bottom) in the '81 and found that all four of the forward seat-mount bolts appear to be already present, but at the back only the two outer studs seem to be present. Since I haven't yet removed the seat and looked under the carpet, for all I know there could already be a socket there to thread a stud or bolt into. What is the usual solution for adding the two remaining seat mounting points on a bench-seat car?
Full bench seat to buckets
My car had/has the split bench, there are four bolts per seat. id imagine that the other two nuts are already in the floor pan, would have costed extra to have two different floor pans for productionhttp://secondhandracing.com/Home.aspx
Yeah, that's what I'm used to dealing with, is the split bench design with eight bolts total. Sounds like I might just have to find a good time to peek under the carpet and see what I can see!2012 Mazda5 Touring | Finally working on the LTD again!
Should get a pair of buckets out of a Thunderbird, lol. That's what I'm doing as long as the person decides they are gonna scrap the car, lol.1984 Ford Crown Vic LTD, The Murphmobile (RIP)
That sounds fun. I'd originally wanted a set of Mark VII seats before these tweed Mustang buckets came up for cheap an hour away. Now I'm thinking they should go in the two-door instead of the wagon because they're pretty decent and they came out of a two-door car anyway.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by torquelover View PostI take it the under body isn't visible enough to see if the floor has the fittings/holes you need? On my car you can see the ground when the bolts are removed.
Originally posted by murphmobile2 View PostDefinately put them in the two door...2012 Mazda5 Touring | Finally working on the LTD again!
Mike, my seats are attached with bolts to the floorpan, both the stock split bench and the SXT buckets (as I re-used the power sliders). Every Panther with split bench I've seen has been like that, bolts through the sliders and the nuts are part of the floorpans. Bet yours has the holes for the extra two bolts, just covered with carper (and likely filled with rubber plugs).
Originally posted by MeLikeyStripperChicks View PostMike, my seats are attached with bolts to the floorpan, both the stock split bench and the SXT buckets (as I re-used the power sliders). Every Panther with split bench I've seen has been like that, bolts through the sliders and the nuts are part of the floorpans. Bet yours has the holes for the extra two bolts, just covered with carper (and likely filled with rubber plugs).
Say Ivan, one of the problems I ran into in mounting the bucket seats on my original '87 seat rails was the fact that the seat rails are curved on top and the bottoms of the newer seats are flat. I tried a piece of square tubing under the front, which resulted in the seat leaning way too far back, but the current version with the tube in back has the seat too high. What was your experience with this issue?2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostSay Ivan, one of the problems I ran into in mounting the bucket seats on my original '87 seat rails was the fact that the seat rails are curved on top and the bottoms of the newer seats are flat. I tried a piece of square tubing under the front, which resulted in the seat leaning way too far back, but the current version with the tube in back has the seat too high. What was your experience with this issue?
I have some severly customized buckets in my 85.. When the weather breaks I will take pictures. I used some washers and had to drill holes in the bottom of the seats for the wider panther rails. I am also going to change the passenger side to a power seat setup as well, and custom mount the controls some way when I get the time, as well as run power for the power lunbar controls on them. Right now I am too busy paying off debt to finish this or the engine/trans project I have started.
Buckets = teh win fo sho!!!!sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
