Gauge clusters
    Gauge clusters
    What year Gauge Clusters will swap into my 90
    Colony Park... Is it just 90 and 91?
    Or will the 92 and up fit too and work?
    I have a cluster were the speedo works but the odometer and trip odometer don't?? Go figure
    I was under the impression that it's only the 90-91 that have the "sweep across the whole face" speedo style. The 89 MGM I had had the "two squares" style, but I think it changed in 90, and the 91 I have now has the sweep across the whole face style.
      yup, you need a 90-91 cluster, im not ahundred percent if you can swap merc and crown vic clusters.
        90-94 Lincoln & Mercury clusters will work with the 'film' from your original.
        -Matt
          Matt
          my film from my cluster???
            The green part peels off and you can re-use it on the newer housing.
            -Matt
