Hi again. I want to make my interior beautiful. So I was wondering how to remove the switches off the steering colum because they are rust and or peeling. And the Cruise Control buttons on the steering wheel
Levers and switches
the shifter lever is held in with a single pin. Drive the pin out and the shift lever comes right out.
cruise switch requires removing the steering wheel. once thats off, you'll find some phillips screws running through the back. remove those, and a plate should seperate off the back of the steering wheel. cruise switches will be sandwiched between that backing plate and the steering wheel itself.86 Lincoln Town Car (Galactica).
question!!!!!!!!!! see the purple wire in this pic http://www.grandmarq.net/blaze/Blaze_Pics/TSSR1.JPG
its always been hanging down not connected to anything and i have no clue what it does or if its important. does anyone know? its the very bottom wire below the wheel.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
the tilt lever is threaded in mang.....theres a flat to get a tiny wrench on it near the base
Originally posted by cld783 View Postquestion!!!!!!!!!! see the purple wire in this pic http://www.grandmarq.net/blaze/Blaze_Pics/TSSR1.JPG
its always been hanging down not connected to anything and i have no clue what it does or if its important. does anyone know? its the very bottom wire below the wheel.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Posti think thats the 'you left the key in the hole dummy' dinger wire. if its hooked up and your chime works, it will make noise if you open the door with the keys in.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 86VickyLX View PostThanks Gadget!
I have tilt wheel also.
What about the Tilt wheel release thing?
And how much would I be looking at for these things new?
Thanks to this thread, I finally swapped my early-style multifunction switch into the '87. Since the part that attaches the lever to the turn signal switch itself was broken on the '79 switch (making it very hard to apply the turn signals), I swapped parts around and used the '87 lower part with the '79 upper part to make a functional early-style assembly, which I then installed in the newer car. Yay me!!!
Now maybe one of these days I can deal with refinishing and/or replacing my grody old levers. Cosmetics just haven't been my biggest priority lately .....2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by gadget73 View Posti think thats the 'you left the key in the hole dummy' dinger wire. if its hooked up and your chime works, it will make noise if you open the door with the keys in.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
This is a very interesting thread to me, as the chrome plating on my Townie levers are starting to peel and it's really pissing me off.
Anyone know if any of those aftermarket billet steel levers (such as the ones from Lokar made for GM vehicles) fit, or can be made to fit?Last edited by CheeseSteakJim; 01-19-2008, 08:11 PM.
