Tilt Wheel
    Tilt Wheel
    How hard is it to replace the tilt mecanishm on the sterring wheel. If its to much of a pain can i just put my stock wheel on the coluem.
    wrong place to ask. What does UGHA mean ?
      it is the word you use when you have now words to voice your frustration.
      I think you may have to replace the column to fix that.
        why do you want to replace the tilt mechanism?.......they can be repaired if they are loose, just gotta tear the column apart and put loctite on the bolts and tighhten em
          I was told it was introduced by darkknight, our grave-digging pal from Alabama. He comes up with funky new terms from time to time ... maybe it's an Alabama thing? :p
