Door Panel Qurstion??
    The plastic trim piece that holds the window switches, door lock/unlock, and the power mirror adjustment broke. Does anyone know where I can find one? Going to my Ford dealer is a last resort. A proper name for it would be much appreciated also . I've looked at some Mustang parts suppliers just in case I could find one, but I've had no luck with it. Here are a couple pics of it. This is a 1993 MGM. It never fails that the hardest things to replace are the things that break! Thank you!!
    1998 Crown Victoria P71: Former National Institiute of Health vehicle
    1974 VW Beetle
    try your local recking yard or e-bay, someone on here might have one but dont know...i call it the switch cluster but not sure.
      I would definitely look into Teamfordparts, they're cheaper than a regular dealer. There's also always Ebay. The piece is mostly called a bezel or switch bezel.
      1986 Grand Marquis LS 2 Door
        switch panel is what i call em.
        '95 Ford Bronco XL -
        sigpic :rebel:
          Drivers side one is called master switch panel I thought.
            I looked on ebay multiple times and only found one that was included with the switches. Only problem is, the plastic moulding has the same problems as mine.
            1974 VW Beetle
              Junkyard
                Yep, I'll have to go there this week. Horaay for Christmas break! I'm free all next week!
                1974 VW Beetle
