Slow windows
    Slow windows
    My drivers window moves ok, but the rest are dead slow. I replaced my pass. front motor recently and used white lithium grease on the cables, pulleys, and tracks of all doors, with little to no help on improving window speed. And if you try to raise or lower more than one window at a time they barely move at all. Is this common? Is there a way to remedy this?
    I took a can of silicone spray lube, jammed the straw into the felt track and gave it a light squirt as I moved the straw up the felt. It fixed my slow window problems. Careful not to get any on the paint or any future re-paint will give you issues.
      That's normal. Try stepping on the gas when you do this. My thoughts are the windows are drawing a lot of juice. If you step on the gas it should put out more voltage instead of at idle. Nothing to worry about really.
