Aftermarket instrument cluster
    Anyone ever considder making an aftermarket guage setup with a sheet metal replacement for the original cluster? Anyone ever have any experience with say, using autometer fuel guages with the factory sending unit? I hear that with some ingenuity the factory speedo cable can be used with an autometer mechanical speedo. They have the same 1:1 input ratio of the factory unit.
    Quick! Someone measure the opening in the dash! (the inside width/height of the guage bezel, please!)
    2007 F-150 Supercab XLT 4x4
    1997 Jeep Cherokee
    An aftermarket fuel gauge won't work with the factory sending unit--the aftermarket jobs are all made for...I think 80 ohms, and the Ford one is something drastically different (I've read up on all this before, but I don't remember all the details now). You could get an aftermarket sender to go with it and probably rig up something that would work decent.
      The autometer description says that the fuel guages operate on 0 to 90 ohms. Anyone know for sure about this?
      1997 Jeep Cherokee
        The have programmable fuel gauges that work with all models, and they also sell different range ones for chevy, ford, ect....
          I've thought about making a blank metal tray to cutout holes for gauges awhile back just havent got to it yet. Make a tray to replace the cluster that comes out so that when the gauges are installed, i can overlay the towncar's cluster cover panel and itll look nearly stock unless you notice whats actually behind the plastic bezel
          '80 Town Coupé
            I want an in-dash tach. But teh CV dash opening is sooo small, it'd be hard to fit one in there. I guess a 3 3/8 would work. But I'd also need a 3 3/8 speedo, which is too small for my liking. Oh well. I guess I'll keep guessing until she blows.
              The autometer speedo I bought just required a special custom speedo cable, which I had made for my Merk.
              I haven't installed it yet, though... And most of the fuel gauges are GM shit. However, I will be running a fuel cell with a GM sender, so it's all good
              My idea involves making a complete sheetmetal part of that dash where the instrument cluster goes, and make it conform how I want it.
                Exactly!
                From what I saw on a thread at fullsizebronco.com, if you remove the plastic clip from the stock ford speedo cable and "manufacture" a retaining bracket to slide over the metal end and bolt to the back of the speedo the stock cable will work.
                1997 Jeep Cherokee
                  This one should work:
                  http://store.summitracing.com/partde...5&autoview=sku
                  1997 Jeep Cherokee
                    Dash panels ideas....
                    Check this place out for some ideas... They have some killer looking instrument panels for cars...
                      Yep, yep, and yep. I've not messed with a custom panel that fits into the factory dash, but the mini-dash I slapped together from some plywood and sheet aluminum for testing purposes was a lot of fun. But the Traditional Chrome gauges I bought look dorky against aluminum (aside from the fact that readily-available aluminum sheet is very thin and easy to bend or dent while going to town with the hole saw and metal nibblers), so my current thought is to make a Rolls-Royce or MG style flat wood panel and mount the gauges directly in that. I might have to learn to do veneering if my skills in working with hardwoods don't improve, but it might just be worth it.
                      For the speedo cable, I got tired of constantly pushing the stocker back on while cruising on the highway, so I got a cable for a '68 Mustang (non-Drag Pak) and stuck it in. Works great with no more cussing necessary.
                      Factory fuel sender from my Mercury is 73-10 Ohms. Like I was mentioning on another thread, movement on my 73-10 Ohm fuel gauge was a little odd when I first hooked it up, but it performed perfectly during bench testing while I had the sender out to modify it, so I'm assuming for now that it was a wiring or grounding problem.
                        you could always go digital
                        sigpic"I love it when a plan comes together." Hanibal Smith (A-Team)
                          that's just sweet...saw it in you're earlier post...very kool setup dude! way to be different!
                          yea, I thought about doing an entirely new gauge setup with AutoMeter gauges...still considering it..but not for a while.
                            this is still in the plans- it's just that I want to do the carb/head/cam swap first so I can actually keep up with traffic.
                            1997 Jeep Cherokee
