source for seat belt retractor release buttons?
    Tried looking for this and didn't find an answer. Did we ever find a source for replacement cables for the seat belt retractors? The cable to the button on the Conti broke on the passenger side. Belt was stuck out, I fiddled with it and got it un-stuck and found the cable was snapped at the button end. Its probably the same as a Panther part so if one works for a Vic I can probably adapt it.
    I've never had one of those apart. I don't even know what it looks like to be able to try to look for something.
      I put it back in the car, kind of need a complete extra unit to experiment with. Honestly I could probably fix it if I could figure out how to get the button assembly apart. It appears to be glued, and a gentle poke at it broke a chunk of plastic so I stopped. The cable inside is just thin steel cable, thinner than a bicycle cable but same basic thing. The end at the seat belt has a hat bushing crimped on, fair bet the other does too but mine broke. If its just a piece of steel cable of a length with hat bushings at both ends I could rebuild that if it would come apart.
      Apparently I did not take them from the car I got most of the interior from, and the Towncar ones don't have the cable. The button just goes directly into the retractor. The two door Vics use a cable setup, so do the Mustangs. Some poking around there last night got a bunch of "what is this wire" and "those are all broken" replies, with some "I put SN95 belts in the car to fix that". I wouldn't be opposed to that if an SN95 belt in blue was just a drop-in. I'm not married to originality in this thing I just want it to work.
      the only hitch, it would have to match the stock belts, or I'd need a complete set of 6. If two were different it would drive me nuts.
        I wonder if the cable is similar to floor shifter button cable, just shorter.
          not sure what those look like. This is roughy a foot long, probably 1/16" cable if I had to guess without measuring it. The wire itself and the crimps I can probably get, its figuring out how to get the stupid thing apart in a way that it can go back together thats the trick.
            yeah... that would be the issue. I have no input having never even taken one out.
