I took out my backseat [only the bottom half], and put down a layer of mat. I knew I had some Sludge left over from the trunk [damn near a gallon] also, so I decided to put that down on the floor as well. This is only a small portion of sound deadening, I plan to do much more.
As you can see where the factory sound deadening covered, I had to scrape it all off, most of it just came up from lightly pulling on it. Some of it I had to use a screw driver to scrape it off.
[All Off
I started to lay mat after using Windex to clean the floor. This actually went by very fast, I like deadening this part of the car a lot more than when I deadened the trunk. I plan on finishing when I take off the back part of the seat.
[Done, with that part]
Now, I laid down some thick liquid sound deadener called Spectrum Sludge, I really like this product a lot along with almost all of Second Skin's products.
I taped off, so I wouldn't get any on the seat belts or any other important pieces.
