I baught a mini tach but im not sure where to mount it, I dont want to put a hole im my nice crack free dash but I dont want it down below
Best place to mount a mini tach?
inside the clock hole!!!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I think that would be the best spot for it. You can also mount it on the steering column too.
Originally posted by 1987LTDmastadidnt they teach you in kindergarden that you cant fit the round cylinder in thre square hole??
i mounted mine on the steering column.. the only view obstruction is the gear indicator, so as long as you know that order you shouldn't have to look up over the top of it.. i believe it's a 5" hose clamp that you need to make it look nice, like $2 at the hardware store.
