I just put in a new speedo cable last weekend because the old one was causing the needle to bounce. The new cable fixed that and worked fine all of last week. On my way to work this morning (-22 deg. F. weather) I noticed that the speedo wasn't working. After work, my boss let me roll the car in the shop and check it out. The cable was still hooked up at the speedometer. I'm sure it's still hooked into the trans because it was a good fit and the clip held it good and solid.
Could it be a faulty cable? I'm picking up a new cable tomorrow, but with temps topping out at 0 deg. F. for the next week, I'm not going to get under the car. When the weather shapes up, I'll replace the cable along with the speedometer (have a 140 going in). What is the gizmo called that the cable plugs into on the transmission? Could that cause my dead speedometer?
